Own a RACE TEAM for the cost of an arrive and drive!!
Yes, you read it right. All it takes is you and 3 of your buddies chipping in less than $1,000 each and you get a complete, proven and race ready car along with a garage full of spares to keep you going. $3995 takes it all. Sign up and race tomorrow - Chumpcar, Lemons, WRL, AER - take your pick of any endurance racing league.
Car has been campaigned for the last 4 years on the east coast. Not a podium car but certainly capable and proven for top 25% finishes. Reliable, safe, great starter car for a team. Has lots of room in MPV for further upgrades.
Event history:
2012: 2014:
Road Atlanta Road Atlanta - Sprints
Daytona Watkins Glen
VIR 24 VIR North - Chumpionship
Atlanta Motor Speedway
2 015:
2013: Carolina Motorsports Park
Charlotte Motor Speedway National Corvette Museum Motorsports Park
Atlanta Motorsports Park Charlotte Motor Speedway - Sprints
VIR North - Sprints
Details of each race can be found on our website:
www.gothamcityracing.net
Look in the Autox and track section for additional Youtube videos of the car in action.
1998 Ford Contour, 2.5L V6 (SVT) , Full roll cage, race seat, harnesses, fire system, fuel cell, surge tank, Momo removable steering wheel, lexan side and rear windows. Chumpcar and WRL 2015 inspections and logbooks.
Spare Parts List
ENGINE / TRANSMISSION
Spare engine , tranny, drive shafts, steering rack all on subframe ready to mount (Yes, It's an SVT)
Second spare transmission
Bin of assorted hoses
Spare shifter cable
Spare IMRC (Intake Manifold Runner Control) box and cable
Spare clutch
2 spare ECU's with required matching keys - TESTED!!
NEW - Radiator
NEW - Water Pump
Spare starter
Spare water pump
Spare PS pump
New Serpentine belt
New water pump belt
Spare idler arm
Spare coolant tank
Spare power steering tank
2 spare coil packs
spare set spark plug wires
spare fuse boxes - under hood and in footwell
multiple sets of used Irridium spark plugs
NEW Primary fuel filter
NEW secondary fuel filter
NEW oil filter
SUSPENSION AND STEERING
original suspension springs and struts (F+R)
NEW front control arms - left and right
Spare used control arms (2 sets L&R)
2 spare sets of front spindles, hubs and bearings
1 spare set of rear hubs and bearings
2 spare front hubs
NEW - front hub
NEW front bearing
NEW set front sway bar links
3 spare front tie rod ends
2 spare rear sway bar toe links
NEW -1 rear sway bar toe link
NEW - 2 left front drive shafts
NEW - 1 right drive shaft
spare intermediate drive shaft
WHEELS / TIRES / BRAKES
4 sets 16" Ford OEM Contour/Cougar rims
1 set 15" Enkei light weight rims
1 set new16" Hankook Ventus S1 Noble High Performance All Season tires mounted (for those cold weather/rainy events like RA in Feb. and VIR in Dec.)
Spare front calipers and brackets (L&R)
1 NEW Front caliper rebuild kit
Spare rear calipers and brackets (L&R)
NEW left rear caliper
3 spare sets of used front rotors
spare set used rear rotors
NEW - 3 sets EBC yellow race brake pads
NEW - 1 set Carbotech XP-8 rear brake pads
Set of Hawk HPS rear brake pads
Set of non race front Hawk HP brake pads
BODY
Body panels - hood, skinned RR door, RFfender
2 spare sets of OEM headlights
Hella 500 driving lights (2 on car plus a new spare light)
PM me with any questions.
Event history:
2012: 2014:
2 015:
VIR North - Sprints
Spare Parts List
Spare shifter cable
Spare clutch
NEW - Radiator
NEW - Water Pump
Spare starter
Spare water pump
Spare PS pump
New Serpentine belt
New water pump belt
Spare idler arm
Spare coolant tank
2 spare coil packs
NEW oil filter
2 spare front hubs
NEW - front hub
NEW front bearing
BODY
