For those of you that are planning to participate in the track day at Nelson Ledges, it is time to do your homework. To get the most benefit of your time, and have the most fun, and hopefully stay out of trouble, I highly recommend doing the following:
Memorize the track.
Read writeups about taking a lap on the track. Look at a track map while reading the write up. Try to memorize where you need to be, and what you need to be doing, while entering each corner, going through each corner, and coming out of each corner. Visualize what it will be like.
Here are a couple write-ups I have found just by searching Google...
http://www.soloracer.com/nelson.html
http://everything2.com/title/Nelson+Ledges+Road+Course (an older write-up. The track itself should be the same, the surroundings may have changed)
After you have it memorized, take advantage of all the YouTube videos that people have posted with their laps. Compare what they are doing, how they brake, turn, and accelerate, where they place the car to the right, left, or middle of the track, to what you have memorized. This works best if you watch a video of someone in a vehicle similar to what you/we have. It makes no sense to watch a video of a corvette or race-prepped cobra and visualize yourself doing that (unless you are also in a corvette or race-prepped cobra or similar).
The track's own website does not have a write-up of a lap, but it does have a track map and a video of a hot lap you can watch (after doing your homework). Use this information to your benefit. This will prepare your mind for the day so you can enjoy it instead of feeling lost in a place you don't feel like you belong.
One common thing between the two write-ups I linked above is that they both mention how fast the track is. Plan on going over 100mph at times, followed by fast and hard braking to something less than 60 on a couple occasions per lap. (I saw a comment in a Corvette forum that the guy went from 135 down to 100 to make the left hander turn 12 before slowing down even more for the almost hairpin right turn 13) Make sure your car is ready for this. Do the prep now. Flush your brake fluid (I will be using Ate Type 200 myself this weekend, it's the same as Ate SuperBlue except it is Amber in color) and make sure you have sufficient pad life left. Review the tech sheet sample I posted on the other track day thread for an understanding of all that needs to be checked before you get there.
Remember, Safety is the most important thing when at a track. Knowing the track will help you be safe, and have fun, and hopefully be faster than you would have been without the preparation.
Memorize the track.
