"I'm sure everyone has heard this at some point or another and if it wasn't something a powered antenna could fix we probably told them that alot of aftermarket tuners are not as good as the factory and maybe they should try a pioneer becuase they seem the best.....well, I had someone in not too long ago with a subaru imprezza who had a pio 2100 installed and was having horrible reception issues....we tried the usual fixes but it really didn't get any better and when his factory was plugged back in it worked fine. This prompted me to do some research and check alot of manuals and was able to come up with a solution....If you look at the specs of the radio in the manual it should list a "useable sensitivity" spec for fm and am radio tuners. They will range from 8dBf being the best to maybe around 15dBf being pretty poor. Everyone here I'm sure knows what a dB is, but this spec is dB's in relation to femtowatts. Now if you remember correctly, to go up or down 3dB is an a doubling or halving of the original power...in this case lower being better. So the "SuperTuner 3" in pioneers for example are not all created equal. The 2100 is 11dBf, the 3100 is 9dBf and the 4100 is 8dBf and the 5100 goes back to 9dBf etc...well, that being said the 4100 has twice the reception power or capability then the 2100....thats enough to obviously translate into a huge difference. In my particular case he went with the 3100 becuase the 4100 is not available in the store....this was a 2dB increase and as such had 66% more power and range and actually more than solved his problem....so, I just thought I'd throw this out there for anyone that may got stuck with another one of these issues....it's a pretty important spec that is probably misunderstood by most of us.....and by the way, pioneers still have the best reception out of everything we cary except for the 2100 with its low 11dBf stat....all alpines sit at 10.6dBf if I recall...." - Christopher Brookshere is what I was looking for
