Blackcoog
I have a SVT that has the 2nd and 3rd gear grind. I picked up another transmission from a local NECO member. I cracked the case open but I'm no expert on transmissions. I tossed the bad diff and installed a good one I had. Syncros seemed to be ok so I installed the transmission. This transmission has the same 2nd and 3rd gear grind. For a moment there I thought I some how put the old one back in but I didn't... apparently I have really bad luck.
I'm going to fix the old one I have lying in the garage. To fix the 2nd and 3rd gear grind I looked at the MTX75 component list that was posted a while ago. I'm going bare mininum. This car has a stock 2.5L in it and it's going to be a daily driver for a friends dad.
Need to pick up: (ran price check on parts.com and prices have gone up quite a bit on syncros)
1-2 Syncro: F8RZ-7124-AA -> 6S7Z7124E ($97.74)
3-4 Syncro: F8RZ-7124-BA -> 6S7Z7124D ($49.44)
3-4 Syncro Cone: F8RZ-7M000-BB ($49.39) Listed as a roller bearing in one post a while back.
1-2 Inner Blocker Ring: YS4Z-7107-DA ($21.38) (Do I need 2 like mentioned in the excel document?)
1-2 Outer Blocker Ring: F5RZ-7107-B ($24.14) (Do I need 2 like mentioned in the excel document?)
3rd Inner Blocker Ring: F5RZ-7107-DA -> YM2Z7107EB ($12.64)
3rd Outer Blocker Ring: F5RZ-7107-A -> YM2Z7107EB ($12.64)
Do I need anything else? Anyone do this themselves? Do I need a puller or a press?
Thanks,
Chris
Thanks,
Chris
