Teal4Banger
I once put an after-market intake on a dodge daytona (2.5L) which was flexible hose... the hose bounced and flexed when the engine revved. I wan't to say it messed up throttle response as the hose moved rather than forcing air initially. It also looked cheap and stupid. Go the quality rout. You can get some aluminum tubing cheap online and you can get some heavy duty rubber truck radiator tubing elbows from Napa or other parts stores. The most gains IMO for an intake on a zetec will come from eliminating the the extra air boxes and baffles and keeping just the filter box with the stock cold air. The only other change I'm making in regards to the intake is putting a couple of inch diameter holes in and running hose to pull in cold air.. the hose is on the outside of the filter so it won't have a vacuum force to flex it.
