Want to Buy engine and injector wiring harnesses
Status
Not open for further replies.
96MystiqueGS
Wilkes-Barre, PA
Looking for injector and main engine harness for a 1997 Contour, v6, auto, w/AC, w/ABS. I can get more info if needed. I will consider a harness that needs work but ultimately looking for something that doesn't need work.
Just picked one up off of a mystique yesterday with 54k miles. Its exactly what you are looking for and no sign of rotting wires anywhere... $250 shipped
Does it matter which ABS unit the car has? I saw 2 different part numbers in the recall notice depending on the version of ABS.
Also, the $250 shipped is for both the injector and main engine harness,.correct? Mileage means nothing to me, the car that needs the harnesses has 64k on it. As long as the wires look good I'm satisfied.Now just to get the car running and the girlfriend will be satisfied lol
Yes the wiring is in fantastic shape.. I bent and contorted the wiring at some connectors to test its strength and durability and it passed 100% Here are the pics of the harness main and injector harness included.
ABS doesn't plug into this harness that is on the body harness so I don't believe there should be a difference.
This is the only flaw in the harness the plastic piece has fallen out of the alt plug wire.
Status
CLASSIFIEDS RULES
Last Updated: 7/20/22
