Scorpion8
I posted here about an issue with my Zetec upstream oxygen sensor. I have the Haynes Manual out for Contours, and am following the chassis electrical diagram on page 12-29. The O2 sensor is annotated on the left/bottom of the page. Here's my question: I can follow the WH line directly to the ECM junction plug pin 44, and the heater power line VT/YE directly to Fuse 13 in the engine fuse box. The ground line BK/YE is easy to trace, and goes to the battery ground after a solder connection at S57.
The real issue is the sensor signal return line BN, which goes to a solder junction at S58, and the other lines that connect to that thru various other lines connect to Pins 24, 25, 46, 60 and more! If my ground issue is on any one of those, wouldn't it show up as other codes on the CEL? Those all seem to have as a common item the A/T selector lever indicator, so is that simply providing a "run" signal to all these sensors, as otherwise why would the leg of the O2 sensor be tied in to the TSS, Intake Air Sensor, Exhaust Gas Pressure Sensor, etc?
Anybody with some electrical knowledge -- a little help?
