sdad
I have a 95 2.0 w/ac. Blower is now longer working and I am trying to troubleshoot. I am aware of the resistor pack and the blower speed switch issues. These are not my problem. I am working with a Haynes manual, somewhat incomplete and maybe a little erroneous. My issue seems to to be an intermittent in the wiring harness itself, and since I don't have either connector data or good wire color code info, this is stretching out longer than I would like. Anyone have connector pin assignments (labeled as "Cxxx")(I need main fusebox, resistor pack, fan, and heater control panel) and/or a known good diagram for a '95? Any info of junction locations (labeled as "Sxxx")Tough seeing through the frost and working in a cold garage. All else fails, I'm going to hardwire, with a toggle switch and inline fuse, directly from the battery to the fan. Now, that's desperate. By the way, the vent position control (at least partially) and heat level control is working.
Thanks for the help
Thanks for the help
