Is there some sort of master diagnostic connector, or "break-out" connector? If so, where is it?
I am trying to diagnose an O2 sensor problem, and some tech info refers to "connector test pins" 60, 93, 71, 91, and 97. Is this somehow just referring to the O2 sensor connector itself? If so, is there an easy way to get voltage readings from those pins while the engine is running (without stripping and splicing wires?). I don't have a real-time obdii scanner.
Thanks!
John
Thanks!
John
