If you are just asking to know if anybody has than I don't think anyone has. If you are asking because you want to run e85 then the first question is why? The post BrApple linked to has good information in it. read it. The only gains I see from E85 is that it is high octane from the pump. So if you have high Compression, advanced timing, or boost it could be beneficial so you don't have to go get race gas every fill up. If you want to do it on a stock engine I would recommend not. You do have to tune the computer for it to run properly and you would pretty much have to wait until your fuel system collapses to find out what parts can't handle the ethanol and replace them with a part that does.
