SVTaslinger
Got some dyno tuning thats gonna be done this Friday.
Heres the combo
Stock block bored .030, square decked
331 bottom end
flat top -4cc pistons
Anderson Ford Motorsport N51HR cam 294 adv. intake duration .540 lift/ 305 exh. dur with .540 lift
Trick Flow 190cc track heat heads milled down to 60cc chambers
Harland Sharp 1.6 rockers
Weiand Stealth dual plane intake thats port matched to Fel Pro 1262 gaskets
650 Holley Ultra DP
Fidanza aluminum flywheel balanced with the rotating assembly at 28 oz
8.8 rear with Trak lok and 3.73 gears
Closest without going over gets the first passenger seat ride at the Dragon Run this year. (as long as the can fit in the car)
Dynojet Dyno BTW
Heres the combo
331 bottom end
650 Holley Ultra DP
Dynojet Dyno BTW
