Did you install the motor? It's a 3L right? To get the oil separator installed (when the heads are on) you have to cut off the basket (on one version of the separator anyway) so it can be jagged due to the previous person that installed it. It's fine/normal.
Your 3L will not come with that piece. It will have a plate covering the hole. You will use a 2.5L oil seperator with a cut basket on the 3L. You will need to slide the seperator between the heads BEFORE you install the modified engine mount between the heads.
Is this a 3L you just bought?
Is it a 3L you are removing from a contour?
What year 3L do you have?
Where did the part come from that you are showing in the picture?
Bought a 03 Taurus engine that has a new one on it. 18k mile engine "not new"
The part I'm showing is from the old blowed up 3L that I thought I needed to put on new engine while taking old one off.
So Can I use the one already on the engine then? or is it engine specific?
