Well here's what happened. After an hour and a half of removing, cleaning, and retightening grounds, it still didnt start so I traced a wiring diagram to find what components came after the fuse that was blowing (fuse 41). The first component in the circuit was the ignition transformer capacitor. In other words the little thing that is bolted down with the coil pack, and serves as a voltage storage and is connected in series with the coil. So i figured why not start there.
Sure enough, i had looped the capacitors power wire under the unit, and the ground bolt pinched it, and exposed the wire. It was a direct short to ground.
Upon fixing that, the car cranked, but nothing. Its not getting spark. I switched the capacitor with one on another harness. Still nothing.
Im thinking the short via the capacitor blew out the coil pack. I pulled the spark plugs and its getting fuel, but when it cranks it just spins. I dont hear any signs of the engine attempting to fire on its own. Im gonna change the coil today and see what happens
