bobsmystique
I need to replace my coolant tank sensor. the gauge does not read in on the cluster. where is the sensor??
Sent from my iPhone using Tapatalk
wait a second ... I completely miss read the post.
The sensor that mounts into the coolant tank is for the low level light on the dash. Note only the duratec has a low coolant light.
If the temp gauge on the dash is not working then check out the sendors as I indicated.
the sensor for the engine temp gauge then.. it does not show me how hot the engine is running.
