DirtyBird
Ok, first, what I've done, in order.... I replaced the water pump, thermostat, blower resistor and switch, resevior cap, top hose, and did a flush....
Now the problems.
The pump was seeping, thats why I replaced it, no problems after that for a while. Then the thermostat was getting stuck closed randomly and overheating, so I replaced it... THEN the issues started (during a few -30 degree days)....
The heater blower resistor went out, the the switch when out, while it was cold... :nonono:
There was random heat and no hose pressure, so I replaced the resevior cap.
Then the top hose split, after temps warmed up.... (replaced, EXPENSIVE)
Now it drinks anti-freeze like crazy (almost 2gal in a month). It will heat up a little above normal (like 2 needle widths), until I turn the heat on full blast, then back to normal the rest of the trip.
No white or blue smoke from the exhaust, I had a friend follow/race me, and there are no engine leaks that I can see. Although there has been a SLIGHT (but noticable) and progressive power loss during all this car drama. I would say that in total it has overheated to, or almost to, the red line maybe 2 or 3 times, because I couldnt stop the car. When it starts to go up
towards that hot, I turn the heat on full blast and pop the hood to help as much as it can.
There is an odor of anitfreeze a lot of the time. The coolant dash light is on when I start the car, till it comes up to temp, then goes off, usually... But today coming home on the highway, when I would get on the gas and go, the coolant light would come on for a minute, then back off. No overheating, and Fluids were just below max.
When I check the resevior when is cold, the fluid is a little below the MIN line, I take off the cap to add and it bubbles back up past the MAX line....
Im lost here, Thanks for the help.
Now the problems.
