I actually check this forum every 6 months or so, just to see if it's still around. I saw some videos of it on youtube... interesting to say the least.
It was tuned with the help of Warmonger initially. Although on the dyno, I didn't turn the boost up past like 11 or so (IIRC) because the wideband at the dyno showed it going lean.
It "had" 42# delphi injectors and a 255lph hp Walbro pump with an 80mm Lightning MAF...it "should" have had enough fuel...especially at the approx 5000 ft elevation I was at.
Good luck with it...it has changed hands several times and there is no way to know whats going on with it now.
