solo92s10
I have a Early 98 svt and I have an abs light on. I have replaced all abs sensors with used sensors (I know not a sure thing) The front drivers sensor was visually damaged. I Disconnected the battery for a few days and reconnected it started the car and it was out then shut it off, the car then sat for a few more days and the light came back on when i started it up the first day I drove it. I dont know if it was on before the wheels moved or not. Now I have disconnected the battery a few more times and the light is always back on right away with start up. I know there were wiring issues and what not. But what else and what exactly were the issues? Also I know there were two different abs units used? which switched in 99 what are the visual difference and mechanical differences so i can tell If i decide to buy a unit to see if that works. Thanks
