What's the fluid level in the clutch cylinder reservoir? If the weep hole is leaking and no drop in the fluid level in reservoir......
If the weep hole is wet, and yet the clutch cylinder reservoir is not dropping in fluid level, you have something else leaking from the weep hole. What does this fluid look like? Motor oil or transaxle fluid are the two choices. As far as clutch performance - bleed same and report back. These two issues/observations MAY be UNRELATED.
