compudude86
Right now im looking at rebuilding a 98.1 transmission, while i run a newer one as a temporary fix (I use my car for work and need to keep downtime to a single day at max)
I have found "high energy" master/deluxe kits for my year, and had a few questions...
*Is it the clutches and steels that makes it high energy? Is anything else required to be upgraded?
*Is it feasible to upgrade the 2-4 band to the high energy wider version? I see it exists for my year, and I dont see the "skinny band" stocked anymore, though I might not be looking hard enough
*I have run across the "upgraded" direct drum Washer online for $4 (http://www.ebay.com/itm/CD4E-LA4A-E...Parts_Accessories&hash=item2a249b4c58&vxp=mtr), is this also a good idea?
Am I understanding correctly that using a high energy master kit would make the trans Mercon V compatible or required?
The valve body is also going to be inspected and rebuilt/replaced, with the kit to correct/prevent erratic issues(i.e. "shift", "transgo" other names are slipping me (no pun intended))
This is planned to bolt to a 3L, and will have its shift firmness increased and possibly shift points changed in tune, so between that and the upgrades, including a seperate trans cooler and external filter, synth fluid and regular strict maintenance, I think I should get quite a bit of life out of it. If this is a good combo, im planning on rebuilding the temp trans the same way and keep it as a drop-in spare for if and when the original one fails.
I know there are a lot of 3L-CD4E haters, and im aware of the possibilites going into this. Other than that, are there any questions/comments/additions/parts ive missed that should be changed out or upgraded?
