GeoPappas
As the title states, is it possible to remove the battery, start the engine with a jump starter, and let it continue to run? Does the electrical system require a battery between the positive and negative cables?
I am having electrical issues and would like to remove the battery out of the equation (to make sure that it isn't the battery that is causing the issue).
