silverky98
Does anyone know where I can get brembo cross drilled rotors for my 98 svt? I have been looking everywhere but cant seem to find them. Thanks.
why would you want a cross drilled rotor? Just ask Rara, you dont need them. Here is the link Andy gave me a while back when I was asking him about the whole cross drilled thing.
http://www.contour.org/ceg-vb/showthread.php?t=18294&highlight=slotted
I too had in the past fallen victim to the old school knowledge of brakes, but no more.
Brembo, unfortunately, doesn't make a slotted/cross drilled for your car, they do make an OEM one that's a flat finish.
Brembo blanks are awesome I will say. The first set I used on one of my mazdas was so beefy that I couldnt believe it was the same price as some of the no-name rotors I could have ordered instead.
The reason I want cross drilled is because they resist warping. My current set is warped( cheap blank ones). I had a set for my 98 svt cobra and they worked great. Where can I find the blank brembo rotors for the front?
I know even cross drilled rotors will eventually warp, but they run cooler so it takes a bit more for them to warp. Can anyone tell me where to pick up a front set of blank brembos?
You need to forget all the things you've heard about cross drilled rotors. Vented rotors like we have on the front already do a good job of cooling themselves so the staying cooler myth doesn't apply. Just get a good set of rotors and don't worry about warping.I know even cross drilled rotors will eventually warp, but they run cooler so it takes a bit more for them to warp. Can anyone tell me where to pick up a front set of blank brembos?
Ordered a front brembo blank set from gearheadpartsstore.com. They had free shipping so it ended up being cheaper than tiretrack. Hope it solves the warping issue. Thanks to all for the help.
You keep using the word warp so I'll assume you didnt read what I wrote about rotors not warping.
