andreslobo
So you want to try some diagnostics try this
1. To take the ecu out of the equation and use only the hydraulics of the transmission unplug the ROUND plug under the battery to the trans after you have removed the clip holding it on. This allows the trans to operate only in 2nd and reverse. If it does both of those you can move onto other things. If if does not move at all either forward or reverse then life pretty much sucks.
2. If the trans does not move the car at all, get a cheap oil pressure gage and connect it to the oil pump pressure port in the left front wheel well. Look at a trans book for the pressures in each gear. This should tell you the state of the oil pump.
Report back with the results.
