jd2-98s
Well a few weeks ago I was driving the mystique into work and about halfway there it shut down coming up to a traffic light. Wouldn't start back up. A trooper came out of no where and pushed me over to the breakdown lane.
I turned the key on and off and swore the pump wasn't coming on or couldn't hear it with the cars flying by. Called work got a tow. Went out on lunch and it started up. Tried it again and again a few days straight. Wouldn't shut off, no matter how long it would run. Tried wiggle test on harness and wires. Had a few pending codes, lean codes, and one p0320 engine speed/dist sensor. Which points to CKP and Coil. I threw a pump at it (125000 miles on it anyway) and didn't cost me much threw work. Drove it home with out a problem.
Next morring go to work with it again (other car was left at work) dies 15mins later at the Dunk and Donuts. I didn't want to call work again so I left it there and called a cab to take me back to the house and drove the Titan into work (goodbye gas).
I let them know the car would have to sit there a few days. They had no problem with it. I grab a coil pack and a CKP from work. Took all my equipment with me and the F'n thing started. Said to myself screw this put the coil and CKP in it anyway and then saw that the wiring was missing it's jacket for the crank sensor plug and most of the harness was cracked on the upper half of the engine.
Soooo, yeah I don't like to throw parts, at work I usally spend more timing testing to be 150% sure before I install something. But with my car, I figured 200 for pump, filter, tank filter, coil, and CKP sensor not bad at all. I hit off the junkyard and found a 2.5 liter with a pretty damn good harness, I didn't pull the whole thing just the section I wanted which is crank, cam, tps, iac, injectors, sender, front 02 and coil pack. So I'm going to go into the garage down stairs and put it in. I so wish the car wouldn't run so I could of caught what it was. but the P0320 was logged again at the dunk and donuts lot. I guess the mistake was the pump but again for the price and it's age, not a total waste. Even though the wires didn't touch it still isn't good and might be a factor. But now the girl won't ride in it LOL and doesn't want me to drive it to work. And I have someone that wanted to buy it but I won't sell it until I'm 100% sure it's fixed.
