I recently got my AEM wideband prepared to be connected to an Xcal2. I used the 9pin mini din connector and spliced it onto the output from the wideband. So far so good. I grouned the din cable to chassis, but have the wideband itself grouned with the same wires that ground my EL Glow gauges.
Now, with the key on, engine off, the wideband pegs lean, as it should. I measure the voltage coming off the Male end of the din cable and only get 2.35V, if I apply that to the suggested formula of (v*2)+10, I get 14.7.
My assumption is that the voltage with the gauge showing ultra lean should be more like 3.5V which would yield a 17.0 result after running through the formula.
What gives? Should I have the gauge itself grounded to chassis too? And do you really think it will make a dramatic difference? Or, is 2.35V in this situation normal.
