SVT Doood
The 3L I purchased has an Accusump with electric control valve.
I've read the manual that the owner provided me...still a little unsure about whether its set up correctly.
Since the Accusump maintains the engine oil pressure pressure after you turn it off the car...I'm not sure what psi I should be seeing with the engine off.
When the car is running I'm seeing 120psi.
I don't know if I should "start over" and de-power the unit...set the initial charge of 7psi...then power it back up.
Thoughts?
Thoughts?
