fastcougar
So, here is what I have done thus far to rectify the issue ... what is your take on this:
Now for the interesting part ... 70mm TB (70mm before throttle plate, flares to 72mm where it mates to the flange). So, quite a bit of porting must be done. The red outline is the 65mm TB gasket outline. Here I'm removing the "nubs" aft of the EGR path outlets.
"nubs" removed, now widening the bore.
boring complete.
Here is where it gets interesting ... It still needs about 5-6mm more removed, but this will interfere with the EGR path and I don't want to pressurize the EGR passage, so it's time to get creative!
Here you can see the EGR passage exposed on the outside of the TB ... what to do ...
The "spacer" gasket that Warmonger supplied with the TB shows that it will cover the passage just fine ... I plan on using a gasket, then this plate.
Even then, the TB has a built in passage that needs to be blocked off ... this picture illustrates the massive leak that would exist if it's not blocked off.
Some "QuickSteel" will solve that.
And it's what I'm using to block off the EGR passage (for the time being while I port out the bore to 72mm. This picture shows the guides I penned with the TB attached.
The plan is to "flare" the bore so that incoming air doesn't hit a flat surface face on ... horrible for flow. I then plan on using a router bit on my dremel to channel out the EGR passage.
boring complete.
