double_u_4
so i had my CEL checked & it was saying P0122- my TPS is open or shorted, well i just replaced it about 2 or 3 weeks ago. i have the 2.5 throttle body & the black piece the cable connects to with the shield on it(dont know what it is called) & i noticed that when the cable is pulling it is opening the shield in the opposite way the TPS gear turns so it wasnt working properly. so i switched out the cable bracket that goes threw the TB with 1 for a 3L. i noticed this 1 opens the shield the other way, the way the TPS spins. so put thhis 1 on & cleared the light & it seems to be fine now, no light on anymore. but it seems like this 1 is smaller than the 2.5's. the round black piece the cable goes around & latches into. so now i have slack in the cable. but it says the TPS for the 3.0 & the 2.5 are the same. so y would 1 turn 1 way & the other turn the opposite way. the 3L pulls the cable from the bottom & the 2.5 pulls it from the top. i took the 2.5 apart to see if i can get it to pull like the 3L but no way to do it.
this 1 is the 1 from the 3L
This was the 2.5
This was the 2.5
