You could keep the 99 3L heads on the 3L block and run a electric water pump.
I'm pretty sure the few people, maybe 3 or 4, that ran an electric water pump had a 100% failure rate. The idea never caught on.
i got a duratec block, i had water jets sticking out where it should be covered, anyways, i didnt do as much research as i should of in blocks years, the majority of people said 3.0 taurus. i went and got the 3.0 taurus. pretty much my fault haha
For the work needed to make that block work it would've been cheaper to just buy another engine. Even if you weren't able to return the 99 engine you bought. Not to mention if you consider the time its taken to make it work.
Disagree. The large bulk of the first 3L swaps were done this way with great success. Mine included.
