LMAO @ U if you only knew what I just paid for my 3l SVTthought he said 65?
I know exactly squat about SVT stuff....
not a big fan of "sport" trim levels that cost twice the price of buying a base model and making it twice as fast....
PM me... haha
I think I"m still confused, in another thread, they are saying the SVT TB is only 60mm....
ok, so this is for the GT TB then?
I was just confused.
Why would you make a adaptor for the svt tb when you could just use the 3L? They are the same size. Doesnt make since to me unless you are worried about the throttle hookup. In that case all you have to do is a simple swap of the svt throttle wheel onto the 3L TB and whala it hooks up like factory. Am interested in the egr tube since i deleted mine i want to add it back now
that what I thought the the bracket does not have anything to bolt too and that will be the major difference and the spacer will allow for you to use a 65mm TB that does not have the IAC opening up top where i have the 3/4" nipple on the side to be able to plumb the line before the 65mm TB plus some people rather keep there SVT TB too and not have to swap over their wheel. Thanks for the input we are going to sell this part for around $125 plus you have 1 1/4" TB spacer with helix spiral grooves to improve air flow and add little small volume.
Tricker if you do have pics that would be great too joey
yeah i'll get some joey. my setup is using a taurus throttle bracket btw. its still not the best way. i'd totally be interested in your setup because it requires no modification. guys here should note that on an 04/05 manifold there can be clearance issues with polyeurethane roll resistors and the IAC hitting the hood. this would also eliminate that problem
