Problem No.1, my radiator fan does not kick on until very high engine temps (right line of normal bracket). Even then it is sporadic. I'm in michigan and until just a couple hours ago it has been in the mid 40s. The past couple days is when it has been the worst, obviously.
Also, I just recently replaced the engine coolant sensor, but I have no idea if it worked before I replaced it or not. I was trying to fix the dash gauge and have no idea what the engine ran before I swapped out the sensor.
Problem No.2, Dash/Steering Wheel vibration when in gear and stopped. My idle is around 550-600 and it feels as if the engine is idling low and unbalancing because of it. A toe on the throttle or taking it out of gear and the engine smooths out and sits about 700-800 rpm. Engine mounts all appear to be in good shape.
