silverky98
Finally decided to put up my contour for sale. I don't have a way to put pics up. But I'm including a link to my CL ad. Car has 256k miles on body, 90k on motor and 65k miles on;
http://louisville.craigslist.org/cto/4521673939.html
-3L port matched, 2004 Taurus. Bought from 3lduratec (90k miles)
-keyed tower
-koni struts around
-torsen LSD
-fidanza aluminum flywheel
-upgraded shift forks
-Sachs clutch kit
-msds ceramic coated headers
-b&m short shifter
-gauge pillar, Volts, trans temp, oil pressure
-Bosch alternator
-rack and pinion
-harness conversion
Pre98 trunk with lip spoiler.
I replaced the abs pump with a nos Bosch abs pump. I just changed the ball joints and outer tie rod ends. Car has a check engine light(egr). And the ac does not work(ac condenser). This isn't pefect by any means, but is mechanically sound, drove from Louisville to Chicago for work during 2 years and it never let me down. Just needs some TLC. Selling because I don't drive it anymore.
-keyed tower
-koni struts around
-torsen LSD
-Sachs clutch kit
-b&m short shifter
-Bosch alternator
-rack and pinion
-harness conversion
