sixgunford
- Joined
- Dec 29, 2005
- Messages
- 67
1998.5 Silver Frost SVT:
3L short block and heads (around 80k miles, all new bearings, gaskets, seals, & timing chains), SVT intake, & cams
DMD
BAT struts & springs
Racebits SS headers, BAT y-pipe & cat
Filled roll resistors
Clutchnet yellow pressure plate and kevlar / organic disc
a couple transmission upgrades
Enkei 5-spoke 18's w/ Nankang tires
The transmission is busted. I had a local shop rebuild it and they botched it, had to pull it and send it to Terry Haines to fix it. He did a great job with it but it looks like one problem was still hiding. I made it about 6 months but now makes a grinding noise in forward gears when on the throttle, it's quiet in reverse. I had the ring and pinion replaced and it appears they didn't get the crush sleeve crushed enough. But that's my opinion, I don't know for sure. Regardless, I don't have a place to work on the car so I had to get a new one and the SVT has to go.
Outside is a little rough, interior in pretty good shape. AC isn't working at the moment, other than that it's in pretty good shape. Would make a good parts car if nothing else.
Build thread:
http://www.contour.org/ceg-vb/showthread.php?67247-sixgun-s-3L-build
$1250 OBO
DMD
Build thread:
$1250 OBO
