sixgunford
- Joined
- Dec 29, 2005
- Messages
- 67
Everybody else did one it seems I should too... And I'm sure I will have some questions and need some help along the way.
So here's what I've got... 1998.5 SVT getting 2003 Taurus 3.0L, 85k miles. Doing a port-match setup using the Bugzuki plates. From what I believe I understand, swap EVERYTHING except short block, heads, oil pump, and water pump from 2.5L. I do have a question about the cams as I saw a thread on NECO I think that said the SVT cams made 10 less HP than using the stock 3L's, opinions / facts here?
Anyway, 3L is down to the short block, should be bare tomorrow, getting new main and rod bearings and head gaskets (3L oil looked like chocolate milk...) Had to settle for Sealed Power bearings as Clevite's are on back order.
Looking for used headers, poly mount, clutch, etc. if anybody has them (I will post on classifieds, just throwing it in here, FWIW).
Also, if I go new, I saw someone mention to get a Clutchnet clutch over spec? Looking for an upgrade but still street-able as this is my DD. Any suggestions there?
BTW, what do you guys (and gals) think about an American Flag paint scheme for the motor?
