KAOS_3.0
so I found this today, wondering if it will work?
i have a spare 150mph speedo. Just the speedo..not the whole cluster. It is electronic not mechanical. I could be persuaded to send it to you to play with in exchange for some gaskets i need...G.so I found this today, wondering if it will work?
on the back of the mondeo cluster is a printed circuit in green plastic. The connector that goes into the back of the speedo is an 11 conductor ribbon that has a white plastic plug on the end...I thought just swapping out the speedo would be the simplest way to go. .. G.
no prob
I actually couldn't find the three part timing cover gasket anywere but ford, so...
but I'll check on the cam covergasketes and the IM gasketes.
yes, and the 99-00 (and i think the late 98s as well) speedos are the same way only with 6 pins instead of 3.ok ..sweet. If you hit me with a pm, we can keep this thread to the point.. 150mph Speedo swaps. BTW my tacho has three pins which plug in behind the dial... as does the temp and fuel gauge... G.
The 150mph speedo doesn't have pins like the rest....it has a rectangular socket. It is 11 pin...see photo .. seems it won't work for you guys then. Maybe the whole cluster might be the way to go. We'll have to compare pinouts...they can be re-arranged.. G.yes, and the 99-00 (and i think the late 98s as well) speedos are the same way only with 6 pins instead of 3.
