not to hijack the thread, but a quick tip on fixing dash warp.
all you need is gorilla glue, some medium binder clips and some q-tips.
remove the stock grill piece.apply some gorilla glue to the underside of the dash pad and the metal of the dash
put a binder clip on it
let it dry.
you should be able to fit two binder clips per section of dash between the supports, you will see what i mean once the plastic grill is out of the way.
do the windshield edge first and then the interior edge.
it is kind of hard to get the clips in place, but patience is your friend.
once the whole thing is glued you can put the factory grill back in.
did that make any sense?
