BurritaSVT
I made a full kit to where everyone can do a direct swap no rigging up cheese straps or welding required. The parts will be machined aluminum and also includes a 1 1/2" trottle bpdy spacer. The kit allows you to use 63mm SVT or 65mm TB and utilizes the 3 liter IAC by feeding it through the spacer. We made a EGR adapter prebent to bolt up to the 3 liter EGR valve no welding or copper pipe needed. The coil pack has it own bracket we made that clears the firewall and looks OEM postioned you also will need the fuel rail mod will be needed for most application to avoid brazing the lines.
let me know what you think
