On my way home from work tonight I developed a strange electrical problem. My abs and park brake lights started to flash and now they stay on unless the car is idling. They seem to turn on as soon as I touch the gas pedal. Also, the battery light started to come on when the revs are below 2000 rpm or so. I had some light smoke come from the engine bay when I was sitting at the lights, so I think its probably a short. Anyone had similar or have suggestions as to where to look?
Not likely to be the abs module right?
Thanks.
As a long shot, I have a stage 3 clutch that besides the regular chatter, makes a moaning noise intermittently when I let off the clutch. I thought this was just the clutch but it might be the throw out bearing. Related? Might explain the smoke if the clutch is slipping?
Thanks.
