BumpPerformancedotcom
New CEG'er
- Joined
- Apr 18, 2009
- Messages
- 20
So I bought this car knowing it had these codes which typically are a result of having some sort of air leak thats by passing the maf and therefore being unmetered and cauing both banks to show lean.
So first thing I did was replace the maf, the previous owner did it 10 months ago and I had it warrantied. Why not? Didnt fix
2ndly I sprayed all around the intake upper, lower, egr etc.
Result : Nothing
So I replaced the intake gaskets because with 102k I figured that be my best bet. All day it ran great and nothing. I also checked the pcv and replace it because it was bad.
Next day codes are back. So I blocked off the egr just to make sure that wasnt sticking open.
I was trying to avoid doing the o2s because it seems like that should be the last step and usually not the cause.
So it either has to be the 02s or injectors correct? The injectors look nearly new and they look like the 19lb explorer injectors so Im leaning towards the o2s
The codes are back p1131 p1151 p0171 p0174
Result : Nothing
