Good grief! Please stop taking advice from someone who doesn't know what he is talking about. He's already given you advice that is unsafe and unwise. You're lucky you didn't freeze dry an eye or any skin.
Depending on the ambient temperature, the static pressure in the system should be between 30 and 140 psi. If you don't know how to read a PT chart, then you won't know what it should be. Here's one:
http://highperformancehvac.com/HVAC...c-refrigerant-pressure-temperature-chart.html That pressure doesn't mean it's properly charged, but it does mean it isn't so low as to inhibit compressor operation. In general, the static pressure for R134a is just a bit higher than the ambient temp in degrees Fahrenheit. The low pressure cycling switch should close and enable compressor clutch operation at 45 psi ascending.
The gauges on the el-cheapo charging kits probably just are color coded. You need a real set with numbers. The el-cheap gauges won't tell you dick if the compressor isn't operating. It will show in the red and your next post will include "I let out the extra freon..." or something along that line.
