sand blasting a car will warp every body panel you touch. to much heat being created.
Only partially true...
Blasting sheet metal with sand is a serious art form. I can tell you that "heat" isn't the main factor if you know what you're doing. Heat is only one factor if you go at it balls to the wall.
Look...
Picture a hammer. You take a hammer and you beat on a flat piece of sheet metal. What happens? Is there heat involved in this scenario?
The natural reaction to beating on sheet metal is you stretch it. Now picture sand as thousands upon thousands of mini hammers. What are all those little hammers going to do?
Now, sandblasting newer model cars would be a scary thing to attempt with the thinner skins these days. Which is why its best to limit the amount of sand blasting you have to do. This is where plastics and shells have come into play. These simply do nothing against rust. Shells will take minor surface rust, but not the deep stuff. Plastic, as I said before, does nothing for you in the rust department. So now you need something to attack the rust. Either you get some glass bead or you rock some sand for the rusted areas. Glass bead will lower the percentage of any warping but there still is a chance. Just like there is a chance with sand if you don't know what you're doing.
Blasting is a serious art form which is why I strongly steer you in the direction of someone that may have a handle on it a little better than someone just starting out or has heard nothing but rumors. You would be pretty safe with someone shooting it with plastic. When they are finished have them allow you to take a look at it to see the rusted areas that are left. It might be something you could handle yourself.
I would be slightly on edge though even allowing the blast shop to finish it up for you unless you have done your research and know they are fully capable.
what are you talking about done wash the car down?
Well it all depends on what you mean by "washing the car down". Wiping it down with a wax/degrease remover or something along the lines of Naptha isn't a bad thing. It will help you against fish eye effect in your primer and paint.
Do
NOT use water!!! Water and bare metal equals rust and rust fast!! Which is the exact reason behind staying away from soda blasting and dipping. They pressure wash your bare metal with soap and water. :blackeye: Dumbest thing I've ever heard in the blasting industry!!
They also have major problems with solvents remaining in pinch welded areas. Things appear to be good until the time your shiny beauty finally sees a good hard rain and the solvents wash out of the area a little and chews your paint.
I hope this helps and doesn't come off as me being some kind of shrewd because that isn't how I intended it. My only intention is to steer you in the right direction and help people learn.
