twocontours
95 contour duratec, 86k miles
Car developed an intermittent idle problem. At random times it drops from a steady idle to just about stalling then recovers. No audible vacuum leaks, tried spraying carb cleaner but can't find a location that causes the problem to go away with any consistency (it's intermittent so when it goes away it may or may not be the carb cleaner). Idle drops to zero (engine shuts off) if I remove the IAC connector. No codes. EGR valve operates normal when I pull a vacuum on it. Vacuum gauge reads normal but vacumm drops as car stalls but I don't know if its cause or effect of stalling. I'm out of ideas and ready to replace IAC on a hunch but my hunches are usually wrong and expensive.
Help
Help
