abyssius
Sorry for the long post. I didn't want to leave anything out. My car is a 1998 Mystique LS, 2.5. I've owned since new. I recently changed the plugs for the first time by myself at 120,000 miles. The only other ignition work I've done to this car is in response to a no-spark condition, I replaced the coil pack (which turned out not to be necessary) and replaced the crankshaft position sensor (which turned out to be the cause of the problem). This I did last June, and the car ran flawlessly after that.
Recently, I was experiencing a slight bucking/hesitation on light acceleration. I decided to replace the spark-plugs. I removed the coil pack as I have done before, and I also removed the EGR vacuum regulator (which it turns out I didn't have to do). When I removed the EGR vac reg, some of the small plastic hoses were brittle and consequently cracked. I carefully replaced these hoses with new rubber hose, before I reinstalled the EGR vac reg.
Anyway, after replacing the spark plugs (gapped to 1.3mm) I started the car and it ran okay at first. But, after a while it was running very rough at idle. I noticed that the check engine light began flashing. When I turned off the engine, I observed smoke coming from the connect-pipe that ties the exhaust manifold to the Cat convertor. I checked this forum, found out that a flashing CEL means misfiring. I re-checked the plugs and discovered that cylinder #3 was not firing - (wet plug). I checked the resistance of the wire and I checked continuity all the way through to the tip of the plug. I replaced the coil module with my spare. Restarted the car and still no firing of cylinder #3. I then swapped the wires between cyl 2 and cyl 3 to see if the the no-firing followed the wires, but cyl #3 still failed to fire. I swapped the new plug with an old plug and still the problem remains.
There are slight differences. It seems that after I reset the computer (removed and replaced fuses 4 and 11). The car felt fine and I had full power and RPMs. However, after driving for about a mile, the CEL starts to flash, and I notice a slight roughness in its driveability. The smoke condition has not returned however.
I know I should probably try replacing the wires, but I'm not in a position right now to throw money at this car without knowing for certain this is the problem. The car has never burned a drop of oil since I've owned it and I've always used synthetic oil. I don't want to think that I have a bad cylinder all of a sudden, especially since the car was running okay until I decided to change the plugs. Any tips as to how to proceed would be greatly appreciated. I've grown to love this car and it is still in pretty good shape body and interior wise.
