PurpleMystique
This morning I noticed my battery light flickering at ~4000rpm. Over lunch break it would flicker or go solid above ~2000rpm. After work, the car had a little trouble cranking but finally started. Right out of the parking lot, I lost my tach and the airbag, ABS, brake, fuel, etc. lights all came on, but the car still ran. I made it onto the interstate okay, but noticed if I gave it more than ~20% throttle it'd bog down. I pulled off of the interstate and it got worse, to the point where giving it ANY throttle caused it to bog down. I barely made it to my girlfriend's apartment, where I shut my car off. Trying to restart it results in clicking.
I'm stuck here for now (there are worse places to be stuck, I suppose) but I'm not sure what this would be. Is it a bad battery that wouldn't charge or is it a bad alternator that wouldn't charge a battery. I noticed right off the bat that there was no A/C - the "fan" worked okay, even though it felt a bit weak, but turning the dial to an A/C or defrost position did nothing. The belt seemed fine and had plenty of tension. I can easily pull the battery and have that tested at an auto parts store, should that be my next step, or is it obviously the alternator?
If so, is it worth busting my knuckles and replacing it or should I bite the bullet and have a shop do it? I have the tools and the resources, but maybe not the patience...
