OFace12
New CEG'er
I am having a hard time removing the front door panels on my CSVT. I found all of the 10 screws that were in the "how to remove door panel" sticky, but it still feels like the door is secured somewhere.
"Remove the trim panel by sliding a narrow screwdriver behind the panel through the access hole on the bottom of the grab handle and pressing the panel outwards, it will pop out. There is another large screw behind a smal trim piece at the bottom of the panel's face. Finally remove the screw located behing the door handle itself, it's located behing anothre little pop in trim piece that will pop out with a small screwdriver."
I got the 5 on the outside of the door, I got the one on the sail piece where the air comes out, and I got the one by the speaker grill. I removed 3 screws from behind the trim piece where the door lock and window button are. I also removed that trim piece. When it says to slide the screw driver through the access hole on the bottom of the grab panel, does it mean the handle that you grab to close the door? Or the one to open the door where that trim piece was? I found a hole underneath the handle you use to close the door, but I wasn't able to feel a spring or anything when I put a flathead up there. What am I missing?
Let me know please. I'm installing a new head unit and speakers tomorrow afternoon when the audio place gets the bypass adapter in, so I'm getting everything ready now.
Thanks.
Thanks.
