ford4life
So i have the wires no idea what they are for.
I know the last owner had a amp back there.
any idea??
any idea??
any idea??
looks like dual conductor home audio in-wall speaker cable to me. As stated before probably ran from a 4 channel amp to the door speakers. Do your speakers work now? The fact that one of the channels in each wire has been taped off is confusing. Check the fuse panel and the battery to make sure the previous owner wasnt a moron. I would say just follow it and remove it all.
Correct, look in the Audio FAQ at the top of the audio forums, there is a post in there from me on how to bypass the factory amp. It looks like most of the work is done for you. All you would have to do is
1- get an aftermarket radio
2- hook up the RCA cables (looks like those are there for you already as well)
3- wire up the amp
4- drop the glove box (see the FAQ)
5- unplug the ouput harness from the bottom of the factory amp (see FAQ)
6- plug that pre-wired bypass harness that you have into the output harness.
and your done!
I don't think thats what he did, but I could be wrong. What do I know.
This your old car?
Indeed
That wire was used to power door speakers. it just ran up to the amp and connected there.
