Blackcoog
Pics are up, now will you guys help me when I need it! thanks
-Jeff-
Sounds like either you have a massive leak so you aren't seeing boost or, more likely, you are tapping into the EGR vacuum line which won't see boost because that line doesn't come directly from the intake it comes from another sensor on the back of the manifold. Follow the plastic line connected to the center of the intake back to the firewall. The smaller of the two should go into a rubber boot. That rubber boot should have a few vacuum lines coming out of it. You want to tap into one of those lines. Get a "T" fitting and run your gauge off of that source.
That should fix your problem.
