Cost update for a band only fix. I purchased the band, oil pump gasket and o-rings (last two only), Case gasket, filter, filter seal, accumulator cover w/seal and a CD4E manual. I did not have to replace the plastic thrust washer as mine was in good condition. No special tools kit, just some shade tree ingenuity.
Total parts cost (with my company discount) was ~$75.00 + $33.00 for the manual through bulkpart. Add in some trans fluid and now we're talking roughly
$130.00 and a lot of your time.
Basically, here's the process:
Remove all of the sensors (TR, VSS, TSS),
Pull the oil pan,
Remove the valve body,
Compress and remove the accumulator cover/piston/spring,
Split the case,
Carefully remove and organize the internals,
Remove the oil pump and there she was... The broken band.
I didn't mess with the frictions and steels so I didn't worry about checking my clearances. I just replaced the listed parts, soaked the new band in tranny fluid and reassembled the trans exactly as it was. I should have it all back in the car late Sunday and report whether or not the cheap band fix worked for me.
Chris
