I found this online :
33 | EGR not opening | Clogged or bad EGR, bad EVP/PFE sensor, and even a sluggish O2 can set this.
AFAIK the O2 sensor is original. I'm still thinking of replacing the EGR, but it has been cleaned and had been manually tested and did the suck test which all proved the EGR being functional. I had replaced the DPFE sensor temporally with a friends and got another code but the car ran fine. The EVP(EGR solenoid?) is my last suspicion.
I will check my spark plugs and the wires and triple check my vacuum lines very soon. But still need some ideas.
