rac74
Those with turbos/superchargers with a L/A intercooler, what are the dimensions is the heat exchanger with them?
I'm modifying my old A/C condensor to work since it is basically radiator technology and radiator technology is for cooling water/glycol and it'll be cooling water.
I went as big as I could and cut out a piece 6"x19"x.625" (lxwxd) and will be rewelding the ends and tapping them with AN fittings to recieve the hose for the I/C and send back out. Then make custom brackets to mount it.
Also, what order does your I/C cooling system run starting with the resevoir?
