bensenvill
disk brake swap... everything went wrong...
not really. the suspension setup on these cars is horrible for ease of installation or removal. i could have all four corners off of my mx6 in the time it would take to remove just ONE of the front strut/springs:nonono:So far springs and struts for me, I thought it was going to be easy.....ended up having to call off work the next day because my car was still in pieces.
Headers should be going on in a couple of weeks, I have a feeling that is going to be A LOT worse!
that only apply's if you dont do your own workthe biggest pitta is owning a contour dumping every paycheck you get into fixing the darn thing. on just general repairs
I'll throw one out there that hasn't been mentioned....electric oil pressure sender installed in the correct location behind the A/C compressor. Not as much of a PITA as headers certainly, but more frustrating to me. Multiple runs to Home Depot & Advance for the correct combo of fittings, hose, etc...and that's not even getting into running the electronics & mounting the gauge. :crazy:
Headers made the suspension look easy. If I ever have to do the clutch though, I'm really not looking forward to that.
Matt
